Sobre as trocas de motores partidos pela Porsche
Ahhhhhhhhhhh finalmente encontrei alguma informação sobre isto!
http://www.flat6innovations.com/saving-an-engine-ims-retrofit/53-assembly
"In the following pictures you'll see what is required to assemble a Porsche M96 engine at the Performance Level. This engine started life as a 2.5 Liter M96 from a 1999 Porsche Boxster that had suffered several different modes of failure to include slipped sleeves, failing IMS, and ultimately the "D Chunk" failure that ended in a catastrophic loss of life for the engine.
This engine had previously been "Remanufactured" by Porsche as part of their replacement engine program and the case had been welded in several areas, MMC cylinder sleeves installed, and other standard procedures performed by the Porsche Remanufacturing program. The outside of the case was marked with the tell-tale blue paint so many of these problematic reman engines have been identified by."
A reconstrução parece um bocado foleirinha... Andarem a soldar de novo ? Uhhhhhhhhhhh
Re: Sobre as trocas de motores partidos pela Porsche
E já agora, o retrofit do IMS... Muito interessante!
Aliás, todo o site é bastante interessante. Happy reading!
Muito interessante Pedro...obrigado pela partilha
» Especificações dos motores Porsche!!!
» Alguma informação sobre problemas com os motores da Porsche
» Cayenne Diesel in motores sapo
» Os futuros motores
» Os Motores e o "Cálculo" estequiometrico
